aftermarket rocker arms
Old Mar 6, 2008 | 01:56 AM
97sscamaross's Avatar
I'm wanting to know what kind of performance gains I could see from a rocker arm upgrade. whats the biggest I can go on a stock motor and what all is required to upgrade alone with the rocker arms. is it possible to get a slightly chopped idle on a stock cam by just upgrading to bigger rocker arms?
Old Mar 6, 2008 | 06:44 AM
rskrause's Avatar
Moderator
There is little to no gain from rockers per se, it's the increased lift from increasing the rocker ratio that adds a few hp (on the order of 10hp if you switch to 1.6:1 roller rockers). Apparently, this can be done with stock springs, though it does put them close to coil bind. But a lot of people here report doing it. Switching to 1.6 rokcers will not change your idle quality.
Rich
69z-28
Jan 29, 2016 10:46 PM
KamikaZ28
May 28, 2015 12:45 AM
Sauced
Apr 12, 2015 10:18 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
