Aftermarket Oil Pan vs. ASM Headers
Old Feb 28, 2006 | 05:31 PM
Fastbird93's Avatar
The clearance on the ASM headers is tight. I've got to move to an aftermarket pan due to the newly decided on 383 displacement. What i need to know is if there is an aftermarket pan with clearance for the 3.75 stroke AND will leave enough room on the outside for a set of ASM headers as I'm NOT swapping those out.
Old Feb 28, 2006 | 05:47 PM
jonlil77's Avatar
Re: Aftermarket Oil Pan vs. ASM Headers
have a canton, and needed to do slight grinding of the y pipe flange on the drivers side it slightly hit the pan
Old Feb 28, 2006 | 05:49 PM
Fastbird93's Avatar
Got a part number on the canton?? How many quarts does it hold?
Old Feb 28, 2006 | 05:55 PM
jonlil77's Avatar
holds 6 qts.Bought mine from from sdpc can-242t pickup is can-023. got it in a 383 also.
Old Feb 28, 2006 | 05:59 PM
jonlil77's Avatar
sorry can15-242t and can20-023 checkd invoice
Old Feb 28, 2006 | 09:01 PM
firebirdStud's Avatar
what kind of price did that run you jonlil77?
Old Feb 28, 2006 | 10:31 PM
jonlil77's Avatar
330 to my door for pan and pickup
Old Feb 2, 2007 | 06:28 PM
SS Joe's Avatar
I have the Canton pan, and Random Technology headers (same as AS&M), and while the headers themselves clear, the y-pipe is another story. The drivers side pipe hits the oil pan as it crosses over, and its therefore impossible to bolt up to both headers at the same time, even after some "persuasion". Looks like I get to modify the y-pipe, just like everything else! I'm switching to LTs soon anway, but I'm ready to get this thing going and $$$ is tight.
Old May 5, 2007 | 12:29 PM
tim95z28's Avatar
I have the same problem with RK sport. Just putting together my 383 with 242t pan, and the y pipe hits the pan where it crosses under the motor.
I don't like these headers and y pipe anyway. Do long tubes go straight back past the motor? I don't like the y pipe running under the pan heating the oil.
Those with the canton 242t what headers are you running?
Old May 5, 2007 | 12:42 PM
Fastbird93's Avatar
I knew the canton pan wouldn't clear, but my engine builder got me a Milodon that he says is stock styled with the longer stroke clearance, so we'll see shortly as I'm paying for the motor to be shipped next week.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Elcojoe
Nov 17, 2014 10:27 PM
