After piston swap need to be rebalanced?
Re: After piston swap need to be rebalanced?
Originally Posted by one eyed *****
i could be 100% wrong here but,when balancing an engine dont they just make sure all the pistons are the same weight.so if you had 4 that were 421 and 4 that were 420,you would make them all the same.so going from 396 to 421 shoudl not matter.
i could be completely wrong,but what determines 396 was a "correct" weight.i just though as long as they were all the same you were good.
your car look great btw
Altough here in my country people order crankshaft, rods, pistons and built here without balancing
Just a few days a procharged C5 is built and I told them, should be balanced, but driver doesn't know anything, he just was happy with his setup and gone away with his car
thanks for nice words about my car "one eyed *****"
Originally Posted by JustNO
thats an other thing. 8 pistons MUST be the same weight, but also after 8 pistons change and weight change, so the balance of rotating assembly changes, and need to be rebalance. thats my opinion.
I think there is a misunderstanding here. My current pistons have 396 weight. All of them 396. And The dished ones 417 weight. So there is 21 weight difference for each pistons. If there would be 1,2,3 or 4 its okay but 21 is a big difference. If I got wrong, correct me please.
Originally Posted by Kevin Blown 95 TA
What length rods you have? If you have 6" rods, you could use the Mahle -26cc pistons which weigh 400g.
Catmaigne
Jul 14, 2015 05:17 PM
