after new opti install
Old Feb 14, 2003 | 04:33 PM
irocbob89's Avatar
I finally installed my opti correctly this time, with all the problems i have been having with my vent tubes and timing and stuff. But today when i first firred up the car and it reved fine for a minute but after it was running for a little bit i give it some throttle and it would sputter or hesitate around 2k and then it would level out with more rpms. The wirres are on right and i think every thing is good but my intake boot from the mass air sensor to tb is kinda mangled and i think it might have a hole in it but im not FOR SURE. Would that cause this sputtering or would that be an iginition thing? it has a new coil, ignition moduel and opti. the intake tubbing is from my 89 iroc since this engine is in my iroc. Thanks for the help.
Bobby
Old Feb 14, 2003 | 04:38 PM
RamAir95TA's Avatar
A torn intake bellows will allow unmetered air to enter the engine and cause a host of problems. There's a good chance that that is the cause of your problems.
Old Feb 14, 2003 | 05:15 PM
Scott 97 Z28's Avatar
Maybe, but I doubt it...
My intake elbow was torn on the bottom where I couldn' t see it and I never had a clue until the next time I took it off. I'd bet you still have an ignition issue...
Old Feb 14, 2003 | 07:01 PM
irocbob89's Avatar
I dont know what the heck it is, but im soo tirred of it. Any info guys???
Old Feb 14, 2003 | 10:11 PM
Hyperspeed97z28's Avatar
Its probably the worn n torn elbow, it will make a difference, especially with just redoin the opti, the computer has to relearn its settings and with the torn elbow it would be all screwy.....
Old Feb 15, 2003 | 12:37 AM
ChuckZ28's Avatar
What do you guys think about the vortech intake elbow? I need a new one as well and was thinking the 1LE but when it gets old it will crack too. Any problems with the metal one? It cant make too much of a heat difference can it?
Sergio
Jan 27, 2016 04:27 PM
maybe2fast
Mar 16, 2015 11:59 AM
GigaMp3z
Feb 20, 2003 02:57 PM
