afr hydra rev kit.
Old Nov 18, 2005 | 03:44 PM
firebirdStud's Avatar
afr hydra rev kit.
Is this a necissary mod to say a stroker, plannin on runnin stock replacement lifters, with afr 210cc afr heads? Will I really see a difference? Or should I not waste my time and money on a daily driver?
Old Nov 18, 2005 | 03:51 PM
blkchevyz's Avatar
Re: afr hydra rev kit.
depends on how agressive your cam is and how high your going to spin it.
Old Nov 18, 2005 | 04:14 PM
1racerdude's Avatar
As long as your valve springs are adequate to control the valves ya don't need a rev kit.
The last one I run put metal shavings in the engine from the locater plate that sits under the head.
Old Nov 18, 2005 | 04:24 PM
so invest in a good set of comp beehives and Ill be alright??
Old Nov 18, 2005 | 04:31 PM
1racerdude's Avatar
Good to go.
G-BODYT56
Jan 14, 2022 11:14 PM
KYWes
Sep 26, 2015 08:49 AM
Bigtoyz97
Sep 21, 2015 01:44 PM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
