AFR hydra-rev
Old May 15, 2005 | 06:02 PM
firebird84's Avatar
AFR hydra-rev
Is anyone using afr's hydrarev kit with stock lifters? If you do how do you like it and have you had any problems. thank you
Old May 15, 2005 | 06:59 PM
bunker's Avatar
Re: AFR hydra-rev
I am with Comp R's, same thing you use the stock lifter version for Comp R's as well because its "STOCK DESIGN"
Works great! Once my outer valve spring broke and the first thing I though was thank God for the Rev kit keeping the lifter on the cam.
Old May 15, 2005 | 07:07 PM
ForceFedZ's Avatar
Re: AFR hydra-rev
I got a Hydra rev kit and I was gonna use it but I decided not to cause i was using Comp 987 springs. My kit is up for sale if you dont already have one. PM me.
Old May 15, 2005 | 07:49 PM
JustNO's Avatar
Re: AFR hydra-rev
My engine builder said its not necessary to use hydra-rev kit .. I use comp R series Lifters.. Why he thinks like that?? cam: 237/245dur. 582/592lifts.
Old May 16, 2005 | 01:10 PM
firebird84's Avatar
Re: AFR hydra-rev
Email me at Smokey_3917@hotmail.com if you still have the kit and how much you want for it thanks dan
Old May 16, 2005 | 02:22 PM
bunker's Avatar
Re: AFR hydra-rev
I dunno I think its a must!
Old May 17, 2005 | 01:47 PM
SS MPSTR's Avatar
Re: AFR hydra-rev
I think your builder is right. Side note: how do you like that cam?
Old May 17, 2005 | 02:14 PM
JustNO's Avatar
Re: AFR hydra-rev
I didn't drive yet.. (assembly didn't finish yet) Cam Motion suggested this cam specs.. I think its too hard for a street/strip drivable car ,but they don't like this.. We will see (its 113 lsa >> nitrous friendly)
Old May 17, 2005 | 04:06 PM
SS MPSTR's Avatar
Re: AFR hydra-rev
Too bad it's not on a 110 - you'd really like it. It's a big myth that the wide LSA is necessary for nitrous friendly applications.
Old May 17, 2005 | 04:18 PM
JustNO's Avatar
Re: AFR hydra-rev
yeah everybody says that I should feel nitrous before I die thats why I get a nitrous friendly camshaft.. Also 110 lsa make more power than 113 lsa right? This difference can be ~~hp??
Old May 18, 2005 | 10:37 AM
JustNO's Avatar
Re: AFR hydra-rev
Why do you think my builder is right?? Everybody says vice versa (they think that I should use hydra rev kit) I can't understand why there are different suggestions
Old May 18, 2005 | 10:48 AM
Cwynn's Avatar
Re: AFR hydra-rev
It's added insurance. If you have the $200, and there's nothing else that you think you need right now then I would do it. I'm planning on buying one when I replace my stock lifters which need to go.
Old May 18, 2005 | 11:39 AM
JustNO's Avatar
Re: AFR hydra-rev
Your cam specs are similar to mine.. Which springs do you use for your 570lifts camshaft??
Old May 18, 2005 | 11:55 AM
Cwynn's Avatar
Re: AFR hydra-rev
Comp 987 double valvesprings. I think that I might have to go with something slightly stronger though.
Old May 18, 2005 | 01:59 PM
turbo_Z's Avatar
Re: AFR hydra-rev
If you go with the 987 then you better get the rev kit to help in the upper RPMs where those springs may not prevent valve float. You should take a look at the LS1 beehive springs.
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
FryedClutch
Sep 1, 2015 08:24 AM
bunker
Aug 21, 2015 10:21 AM
