AFR Heads vs LT4 Heads
Old Jul 13, 2003 | 12:48 AM
Joe94Z's Avatar
Which heads are better? price, performance are all going into consideration here. What do you guys think?
Joey
Old Jul 13, 2003 | 07:34 AM
rskrause's Avatar
Moderator
Re: AFR Heads vs LT4 Heads
Joey
Are you talking about buying new heads or porting what you have? What are your goals, how will you use the car?
Rich Krause
Old Jul 13, 2003 | 08:13 AM
OldSStroker's Avatar
Re: Re: AFR Heads vs LT4 Heads
Rich Krause
Good questions.
Also, what kind of a budget for the engine?
Old Jul 13, 2003 | 04:57 PM
Joe94Z's Avatar
I will port the heads no matter what. The car will see the track more than anything. Drivability will not be a concern because I have a daily driver. I just don't know which heads i should get afr or lt4.
Old Jul 13, 2003 | 10:03 PM
Joe94Z's Avatar
TTT
Old Jul 13, 2003 | 10:20 PM
rskrause's Avatar
Moderator
I'd like to help, but I still don't know what you are building. Street car, street/strip, race? NA, blower, nitrous? Displacement, rpm range? Etc.
In very general terms: the AFR's have higher performance potential but are more expensive because you have to buy a new set of castings to start with. OTOH, a set of ported LT4 castings can flow quite well for a 23 degree head. If you are buying new castings, get the AFR. If you already have the LT4's, stay with them unless it's a relatively high budget, max performance application. Even relatively mild blower cars especially can benefit from the AFR castings because you can get them with a combustion chamber as large as 74cc. This allows for a low CR without a huge piston dish. Also, the thicker deck is nice as it is more rigid and promotes gasket retention.
If you have very deep pockets, you can adapt a set of 15 or 18 degree gen I heads to your LT1, or just swap out the LT1 for a gen I engine. Or if you are a .com millionaire, get a set of Arao 4-valvers. http://www.araoengineering.com/ Figure $8-10,000 for the whole package unless you are a skilled fabricator and can make your own headers and intake, etc.
So, as the Old Stroker said, budget is a big part of this choice.
Rich Krause
Old Jul 13, 2003 | 11:09 PM
Joe94Z's Avatar
The car is gonna be a street/strip car, but more for the strip. I'm going with a brand new 350 setup possibly a 355. I'm hoping for a mid to high 11 sec car. The car might see nitrous, a 100 shot at most. I'm leaning towards a set of S2 LT4 heads form somewhere. or either a bare set of lt4 heads and just port them somewherw which ever is cheaper. I'm kinda on a budget.
joey
Old Jul 13, 2003 | 11:55 PM
zhevy-1's Avatar
The AFR 190cc can get up to 280cfm @.550 lift with a competition type port job. I'm sure more if you can find a good porter out there.
So, it's a matter of what your goals are. I've said the AFR 190cc as an example, since they're close in price for what you would pay for a good set of LT4 heads ported.
Old Jul 14, 2003 | 01:02 AM
Joe94Z's Avatar
As far as rwhp i want to achieve somewhere around 400-420 rwhp. Hope this helps.
Old Jul 14, 2003 | 07:28 AM
rskrause's Avatar
Moderator
Joe: if you have to buy new cores the AFR isn't much more expensive. And it does have more potential.
Rich Krause
Old Jul 14, 2003 | 02:00 PM
Joe94Z's Avatar
How much would a new set of afr's cost?
Old Jul 14, 2003 | 03:07 PM
96z's Avatar
96z
There is GP being run by Bret Bauer for AFR 195's I think. Here is the link
http://web.camaross.com/forums/showt...hreadid=143341
Old Jul 14, 2003 | 03:08 PM
rskrause's Avatar
Moderator
There's a price sheet on their web page.
Rich Krause
LeftoverChinese
Jan 14, 2024 03:03 PM
Potent77
Apr 1, 2015 12:45 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
