AFR heads question
Old Jan 14, 2009 | 01:52 AM
mrmint69's Avatar
AFR heads question
Found these heads on Ebay and wanted to know if they work with the LT1 or if you need the Lt4 manifold and anything else? http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Here is the website he talks about with the part number he says.
http://www.airflowresearch.com/210sbc_lt4.php
The part is #1057
Old Jan 14, 2009 | 02:36 AM
ak95ta's Avatar
Looks like you will need the LT4 intake with those. Theres a pretty decent priced one on the for sale section. https://www.camaroz28.com/forums/sho...d.php?t=658043
Old Jan 14, 2009 | 02:47 AM
96lt4vette's Avatar
Correct, you definitely need an LT4 manifold. It will also need some port work to match up to the heads perfectly. I have those on my car.
Also, It's hard to tell exactly from those pictures, but they may be the old style AFR heads, not the new "Eliminator" heads (AFR's website lists specs for the new ones which just came out last year). The old ones flowed a bit less and also were known for having some oil drainback issues.
I'd recommend asking the guy specifically when he bought them. 1057 eliminators run right around $2K new. The older ones are worth a bit less. Unfortunately both lines use the same part numbers.
Highlander
Jan 12, 2020 02:13 PM
parkers Z28
Mar 11, 2016 08:14 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
Highlander
Aug 9, 2002 02:30 AM
