AFR Heads
Old Feb 2, 2004 | 12:11 PM
94Formula/TA's Avatar
AFR Heads
If I can pick up a set of AFR 195cc heads that flow 290+/200+ would it be worth it instead of getting a good set of stock ported heads in the 275/200 range?
Im using a mild cam 218/224 .528/.536 (w/ 1.6) 114lsa.
Old Feb 2, 2004 | 12:17 PM
RacinLT1's Avatar
go for it,worked afr's are better then stockers IMO anyday.
box stock afr's arent all that,but those numbers aint bad.
Old Feb 2, 2004 | 12:24 PM
AsianSensation's Avatar
If you got the cash, I'd say why not. But be prepare to wait a long time. Took AFR 18 weeks for them to deliver my 195cc's
Old Feb 2, 2004 | 02:40 PM
Would 36# injectors be too much for just the heads and cam? Should I go with 30#, and will I need a new fuel pump?
Old Feb 2, 2004 | 02:43 PM
RacinLT1's Avatar
if it's stock bottom end,i dont see why anything more then 30's would be needed. fuel pump cant hurt,but you could try the stocker.
Highlander
Jan 12, 2020 02:13 PM
parkers Z28
Mar 11, 2016 08:14 PM
95maroboi
Jun 7, 2015 12:18 PM
MadMav
Feb 6, 2015 11:02 PM
Highlander
Aug 9, 2002 02:30 AM
