AFR head question
Old Feb 16, 2004 | 12:13 PM
Gripenfelter's Avatar
AFR head question
If you get the LT4 AFRs, will they absolutely not work with the LT1s?
If this is the case, where can I get an LT4 intake?
Old Feb 16, 2004 | 12:18 PM
slopokrodrigez's Avatar
From Summit.
http://store.summitracing.com/partde...NAL%2D12550630
or GMpartsdirect for $202.00
Old Feb 16, 2004 | 12:25 PM
Thanx dude.
Do you by chance know the LT1 runner size?
Old Feb 16, 2004 | 01:49 PM
Phew I'm gona have a brain hemmorage if I try to remember that one. Shoot a PM to Injuneer. By the way I don't think you can port match to the gasket. Check it on both pieces before you do anything.
Old Feb 16, 2004 | 03:58 PM
Sent you a PM.
Old Feb 16, 2004 | 08:20 PM
engineermike's Avatar
I compared an LT1 and LT4 intake side-by-side and saw little or no difference. The LT4 ports are narrower at the top, but the location appears to be the same.
Mike
Old Feb 17, 2004 | 06:43 PM
arnie's Avatar
Originally posted by engineermike
I compared an LT1 and LT4 intake side-by-side...
Mike, what year LT1 intake did you use for the comparo?
Old Feb 17, 2004 | 06:52 PM
1995
Old Feb 17, 2004 | 08:13 PM
arnie's Avatar
'96-97, and some late '95 intakes have port shape, at flange, to replicate that of the LT4s. Earlier intakes had a crisp rectangular shape to them, unlike the LT4 intakes, or the intake ports of LT1/4 heads, of any years.
Old Feb 17, 2004 | 10:20 PM
Mine had rectangular ports that are actually larger than the stock LT4 ports, which taper narrower at the top.
Highlander
Jan 12, 2020 02:13 PM
parkers Z28
Mar 11, 2016 08:14 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
Highlander
Aug 9, 2002 02:30 AM
