AFR Flow #s are in
Old Oct 22, 2004 | 07:06 PM
ejfagala's Avatar
AFR Flow #s are in
I finaly got the flow sheet for my More performance AFR 195s and was alittle disapointed but over all they are close to what I thought they should be. The heads have Ferrera 2.050 Intake and 1.600 exhaust valves and where CNCed by More. I thought they would be up 6-8 across the board but it I only got a 3-4 cfm increase over the AFR comp port claimed flow #s. I still think the 195s will provide some great low end TQ and I should make close to the 425 RWHP I was hoping for when i started this whole thing. I should be able to drop the motor in after I get back from vaction in a week and then it is off to get dyno tuned and we will see.
CFM@ 28''
.200------.300------.400----.500-----.550------.600-----.650
I----E------I---E----I---E----I----E---I----E----I---E----I---E
139-115---205-160-254-185-280-198-283-205-285-210-285-215
Stock Comp ported AFR LT4 195s
135 110 -201- 157- 249 180- 275 195 280 202 280 208 282 212
Old Oct 22, 2004 | 07:24 PM
95_LT1_6SPD's Avatar
Re: AFR Flow #s are in
did you have them flowed before the cnc porting? I would like to see how much they really got improved. Becaue compared to the claimed numbers, it seems like a waste of money.
Old Oct 22, 2004 | 07:39 PM
amean94ta's Avatar
my stage 3 lt1 castings are about the same i think you got ripped
Old Oct 22, 2004 | 08:08 PM
ejfagala's Avatar
I defenatly did not get ripped off. More charged me the same price as the normal AFR comp ported heads. If you have a set of LT1 heads flowing the same as these then you have one hell of a set of ported LT1 cast heads (8 CFM across the board is huge). I was expecting a little moe because of the larger valves and new seats but I wanted to keep the low end TQ of the smaller heads. If I was only looking for high flow #s I would have just went with 220's but I was looking for #s across the board that would help me make my power at lower RPMs rather then 6-7K
Old Oct 22, 2004 | 08:17 PM
rskrause's Avatar
Moderator
Those are good numbers for a full port job on an AFR 195cc head. They should work well.
Rich
Old Oct 23, 2004 | 12:51 PM
amean94ta's Avatar
i am not taking anything from the flow #'s those are great. my point was the amount of money you spent to get them was high. what is the rest of your combo to think your at 425 rwhp?
Formula Steve
Sep 19, 2023 08:31 AM
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Daluchman1974
Sep 11, 2015 06:12 AM
