afr 220 vs. le3 heads...
Old Apr 28, 2005 | 11:14 AM
DiabloGT's Avatar
im wondering how much of a difference in power would the afr 220s make more than the le3? and can the afr 220s still be ported and polished?
thanks
Old Apr 28, 2005 | 11:20 AM
RealQuick's Avatar
Re: afr 220 vs. le3 heads...
thanks
It depends on alot of things. One is are you going to get them ported right from AFR? If so, then the gains will be less than if you get the castings from AFR and have Lloyd or AI or someone else port them.
Lloyd got much better numbers then the Comp. port AFR210's when he ported the bare AFR210's for me.
Old Apr 28, 2005 | 11:30 AM
DiabloGT's Avatar
would he still charge the same prices like his le3? would ai do any better or not really worth the extra money?
Old Apr 28, 2005 | 11:39 AM
RealQuick's Avatar
He charged me ~700ish to port my unported "as cast" AFR210's. I suplied the AFR's. Whether AI does a better job, who knows. To me, the dollar difference between them was too high.
Old Apr 28, 2005 | 11:41 AM
DiabloGT's Avatar
the $700 was for a le1 port on yours?
Old Apr 28, 2005 | 04:25 PM
DiabloGT's Avatar
does anyone know? are these afr 220 heads any good for turbos? and i heard that like the 210s fit better and u can use normal rockers? so are the 210s any better? how much of a hp diff is the fully ported afr 210 compared to le3 stock heads
Old Apr 28, 2005 | 07:10 PM
jkipp84's Avatar
Here's a good way to find out: www.eportworks.com
Old Apr 28, 2005 | 07:41 PM
n2oblkz
Guest
Posts: n/a
Posted by: RealQuick
I got a quote from LE on my bare AFR 210's and it was approx. $1300.00. Was your's complete heads or just the port work? I called and talked to AI just the other day and they said that that are getting set up for CNC work and they would do them for approx. $1000.00.
Old Apr 28, 2005 | 07:54 PM
LT1OWNZ's Avatar
I think that 1300 from loyd would be a full port with valves spings retainers and locks, the AI port job will probably be only the actual porting for 1000.
Old Apr 28, 2005 | 08:10 PM
tireburnin's Avatar
If you need AFR 220s then you wouldn't even put an LE3 head in a comparison. One is a ported stock head and the other is for an all out no holds barred kind of motor.
It would be like comparing Rosanne (or some other homely woman) and Carmen Electra...They are both women, but thats where the similarities end.
The two heads have different cross sections, compressions (combustion chamber size), and a number of other things. You need to know your goal and budget before looking at heads. Figure out what you want and how much you can spend.
If you are in the market for either...do a search and/or look at other people's setup. There is a ton of info out there.
Old Apr 28, 2005 | 09:08 PM
DiabloGT's Avatar
lol thanks for the wierd comparison, would ported afr 210's be good enough to handle a ptk turbo kit (in 1-2 years im plannin for one) and would the lt1 or lt4 intake work with it? how would i make it fit i heard something about some modification to it?
thanks
Old Apr 29, 2005 | 04:36 AM
n2oblkz
Guest
Posts: n/a
If you go with the AFR 210's or 220's, you will have to use the LT4 inake. The 220's would be really good for a turbo/blower motor, that's why I bought mine. INTMD8 here on the board made 847 RWHP with his turbo setup and I think that he has AFR 210's.
Old Apr 29, 2005 | 08:18 AM
RealQuick's Avatar
To port my AFR's. He charged me $400 to port my LE2's about 2 years ago
Old Apr 29, 2005 | 08:19 AM
RealQuick's Avatar
$700 for just the port work. No valvetrain at all.
Old Apr 29, 2005 | 08:21 AM
RealQuick's Avatar
thanks
One of the PTK customer's made 9XXrwhp with a T76 turbo and ported LT1 stock castings.
