AFR 210cc LT4 Race Ready heads
Old Apr 28, 2003 | 09:52 AM
F6's Avatar
F6
Is anyone using these heads on his 396?
I need info: will I have any trouble with these heads and a 230/236 Comp Cam, as a daily driver. CR=11.3:1
Old Apr 28, 2003 | 01:24 PM
kmook's Avatar
Advanced Tech Moderator
I will assume you have an LT1 from the heads you refrence (please make and use a signature so that people can tell what car you have). I will move this to LT1 Tech as a general question like this should be posted there.
Thank you.
Old Apr 29, 2003 | 03:24 AM
F6's Avatar
F6
I forgot to say I'll be using 95 octane.
I'ts amazing that nobody has commented this thread.
Old Apr 29, 2003 | 04:49 AM
eddiezlt1's Avatar
Re: AFR 210cc LT4 Race Ready heads
cams to small for the heads
other then that have fun
Old Apr 29, 2003 | 07:17 AM
F6's Avatar
F6
It is supposed to be used as a daily driver and not a race car.
Peak Hp should be at about 5900--6000 rpm and fairly good idle.
2600 TC will also be used
What hyd. roller cam would you suggest.
Old Apr 29, 2003 | 08:45 AM
n2oCamaro's Avatar
Since your ride will be a daily driver and you want a 6000 rpm peak, you should go with a smaller cc head. This will improve the velocity and low end power. The 230/236 cam would be great with a set of 190cc or 195cc ported heads. You would probably want a larger converter though. Just my .02
RUENUF
May 25, 2016 08:10 PM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
