AFPR issues
Old Jun 10, 2005 | 10:14 PM
DarkHorse's Avatar
AFPR issues
I have the adjustment screw turned all the way out on my AFPR but the pressure is still at 40psi with the hose on 45 off. Is the AFPR dead? I have a stock unit I can put back on if need be. Not sure on the manufacturer - bought it off of a buddy of mine.
Old Jun 10, 2005 | 11:58 PM
OBE1 95Z28's Avatar
Re: AFPR issues
Does it adjust when you screw in the adjustment nut? I'm running a TPIS AFPR and have mine set at 60 psi with the vacuum line off (new injectors coming to fix that issue ).
Old Jun 11, 2005 | 12:54 AM
DarkHorse's Avatar
Re: AFPR issues
Ahh, good question - I didn't try screwing it in to see if the pressure went up.
Old Jun 11, 2005 | 12:57 AM
markinkc69z's Avatar
Re: AFPR issues
Your return line might be pinched somewhere.
Old Jun 11, 2005 | 07:25 PM
DarkHorse's Avatar
Re: AFPR issues
I have a Racetronix fuel pump kit with install harness - would this pump be causing me a problem with higher fuel pressure?
Does it sound like the regulator is toast?
Old Jun 11, 2005 | 09:18 PM
Re: AFPR issues
If you can't control pressure with a higher volume pump then something is restricting the return. The factory regulator and plumbing are sufficient for an intank 255lph pump. I suugest tracing the return line back from the regulator to the tank to see if you can find a kink in the line. It is possible that there is something lodged inside the regulator, but unlikely. There aren't many parts to go bad inside of one. They usually work, or leak.
Old Jun 12, 2005 | 01:26 AM
lunati397's Avatar
Re: AFPR issues
hate to rip on your thread but what are you going to set your pressure at I am putting one in next week and im wondering what to run the pressure at I have 37lbs injectors
Drtryder
Apr 22, 2015 04:17 PM
87Aerocoupe
Mar 20, 2015 01:23 AM
CobraEatr
Jul 24, 2004 11:37 AM
IROC-Z305
3rd Gen / L98 Engine Tech
Jul 19, 2002 05:43 PM
taner
Jun 20, 2002 01:28 AM
