AFGS with LE2
Old May 24, 2005 | 12:23 AM
  #16
blksunshine's Avatar
Re: AFGS with LE2
I also hit about 370-380afgs thru an auto with le2 cam and heads, I am sure you would pick up some power with some 30lb injectors.
When i had cc305 cam with GTp heads my AFGS was 300 and it dynoed 325rwhp, so I think its pretty close. But trap seep is more about weight and rwhp
Old May 24, 2005 | 02:16 AM
  #17
qndzia's Avatar
Re: AFGS with LE2
Originally Posted by 1982z28with18s
Have you actually dyno'd the car? Are you sure it has a 10.2 afr, did you have it wideband calibrated correctly?
No I haven't dyno'd it yet as I was trying to see where is problem with afgs first..
I'm pretty sure that wideband was calibrated correctly - it showed 14.7 at part throttle... when WOT it drop down immediately to around 10.
Old May 24, 2005 | 01:24 PM
  #18
qndzia's Avatar
Re: AFGS with LE2
I know that 30lb injectors would help, but not so much if there is so little air..
I still consider incorrect cam phasing..
Old May 24, 2005 | 04:51 PM
  #19
Re: AFGS with LE2
120% duty cycle, u really need them, You arent suppose to be over 85%. Just tryin to help, I would do the little stuff first.
9t4lt4z28
Oct 2, 2015 10:28 AM
Schul365
Aug 25, 2015 05:47 PM
95Blackhawk
44
Nov 10, 2010 03:11 PM
1982z28with18s
Oct 28, 2004 02:33 AM
sideways_Into_3rd
Advanced Tech
12
Jan 21, 2003 11:44 PM
