Advantages/Disadvantages of a solid roller setup
Old May 6, 2010 | 04:16 PM
Rob94hawk's Avatar
What the above title says. From what I understand sollid rollers are good for engines that utilize the upper rpm ranges 6-8000. Is a solid roller setup pointless on the LT1 because the pcm doesn't read above 7000 rpm? Still looking for ideas.
Old May 6, 2010 | 06:36 PM
Kevin Blown 95 TA's Avatar
Building a 7000 rpm LT1 is pointless unless you are going to race it, then it makes a lot of sense, and then you can get a better operating system if you have to - I have friends who used the stock PCM though and did OK. Hydraulic rollers are pretty good these days and there's pretty good cams for them. There's a bunch of guys here who did solid rollers - maybe they'll chime in on what they did for intakes, valve train, etc. RPMs are expensive and expect more maintenance with solids.
Old May 6, 2010 | 08:49 PM
onefastmx5's Avatar
advantages: higher rpm/ less valvetrain hp loss
disadvantages: more expensive/ frequent adjustments
basically- best for a race car.
Old May 7, 2010 | 01:27 AM
hsyr's Avatar
Great Q
I wouldn't mind hearing some more opinions. Is a solid roller good for a weekend car that would only see cruising and racing? (1/4 mile, and roll racing).
Also at what kind of mileage would a SR setup need to be serviced? Sorry to hijack the thread
I've searched this before just looking for fresh opinions
Old May 7, 2010 | 05:37 AM
A solid roller is really for a high RPM "race" engine. I've got a solid roller, and its really not much more work that an hydraulic. Maybe check the valve adjustment once a year or at 6,000 miles. Drove the car for two years as a daily driver with no problems. Does eliminate the use of the knock sensor, because there is too much noise.
I wouldn't do it again with the exact setup I have. My peak HP NA is well below 7,000rpm, and even with the 300-shot, the nitrous cuts off at 7,000rpm. Redline is set at 7,400rpm. ECU is a MoTeC M48Pro, so RPM with the stock PCM is not an issue.
If you do it, you need top quality lifters for daily driving. I use the Crower Severe Duty Cutaway lifters.
But the sound of the valve train is enough to make it worthwhile
bunker
Aug 1, 2015 10:10 PM
detroitmuscle
Jul 31, 2015 04:21 AM
realistyc
Jul 28, 2015 07:32 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Noct
Jul 14, 2015 01:18 AM
