Advanced Induction "Full Port" heads and cam came in today! (pics)
Old Jul 2, 2004 | 11:53 PM
  #16
Dave88LX's Avatar
Originally posted by 97Z-M6
i figured that much, but how can you compare heads flowed at 4.030 bore with heads at a standard bore.
No clue about that one. How much of an effect would it have? Would flowing it at 4.000" make it flow more/less/negligible difference?
Old Jul 2, 2004 | 11:55 PM
  #17
SS MPSTR's Avatar
Originally posted by Dave88LX
PM'd you, waiting for a reply. My reaction was the same as yours though Next Friday?!? Nice! I bet your psyched! Bauer Racing Engines has mine now, balancing should be next week hopefully and go from there. I'm shooting for a running car the 1st or 2nd week of August, for an Aug 14th race.
Replied, and you're going to be in that car every waking moment to get some miles on her before the racing on Aug 14th
Old Jul 3, 2004 | 12:08 AM
  #18
Dave88LX's Avatar
Oh no doubt! Well, I can take a drive out to NY and back to MA and it should be ready to go I need to figure out how to break in an engine and clutch at the same time, WTF heh.
YGPM!
Old Jul 3, 2004 | 12:59 AM
  #19
atljar's Avatar
Comments...IM JEALOUS!
Common Phil, call AFR and yell at them for me, lol.
Old Jul 3, 2004 | 02:05 AM
  #20
5.0THIS's Avatar
if they work as good as they look you'll be in good shape
Old Jul 3, 2004 | 10:19 AM
  #21
Turbo6's Avatar
4.030 is a pretty standard bore size used on flow benches for measuring head flow because most that buy aftermarket heads will have this bore size. If you use a 4.000 bore size, you would maybe lose a couple CFM, but with the moderate sized valves in these LT1 heads, you wouldn't lose too much. If I had to guess, probably less than 5 cfm at higher lifts, and even less at the lower lift values.
Old Jul 3, 2004 | 02:21 PM
  #22
TQdrivenws6's Avatar
http://advancedinduction.com/AiFAQ.html#2
its not even worth mentioning...
Old Jul 11, 2004 | 12:06 PM
  #23
arnie's Avatar
Dave, were the heads you had AI port, the original LT1 heads off the '97 Firebird?
Also, does/did AI enlarge the oem seat to accomodate the larger Ferrea valves, or were new larger seats installed?
Old Jul 11, 2004 | 12:16 PM
  #24
944v8inDFW's Avatar
Awsome Setup!
Hope they work as good as they look!
Old Jul 11, 2004 | 05:38 PM
  #25
Dave88LX's Avatar
Yep original '97 LT1 castings off my car. To be honest I'm not sure exactly what he does to the seat...I know he had to replace one due to a valve guide problem or something...
I know he didn't have to install larger seats though.
Noenav
Mar 1, 2019 07:38 AM
birdblack
Dec 30, 2014 06:59 PM
Noenav
Dec 6, 2014 07:35 PM
Queens94z28
Nov 20, 2014 06:03 PM
NED4SPD
Sep 16, 2002 10:45 PM
