Adjusting the rockers (engine running method)
Hey guys i have a rocker that has developed a tick, im hoping the rocker has just backed off. I have a question when adjusting them using the engine running method can i adjust just that rocker, or do i have to do them all? Thanks for the help.
Tyler
Tyler
Re: Adjusting the rockers (engine running method)
Im pretty sure you can do just that one rocker, just wait until the valve is all the way closed and give it a little tighten. Or you can loosen it up and retight it to whatever valve lash.
Yes you can do one or all...
When I do then running I take a fold of newspaper or cardboard to catch the oil thats going to be tossed around...
Form a U shape a few inches high that slips inside the rim of the head on the lower side, and up a few inches on each end..
Makes a lot less mess that way..
oldschool
Feb 9, 2016 09:21 PM
