adjusted roller rockers, rockers still move?
I adjusted my roller rockers today, tightning them down till zero lash and 1/2 a turn afterwards but I am still able to move the rockers with my hand to side to side, is this okay? They are 1.6 pro mag .. they are self aligning and the springs are comp 987. Should they be able to move like this?
While tightning the rocker arms in sequence, I jiggled the push rods up and down till they wouldn't move up and down anymore and stop tightning the rocker arms immediately after the push rod had no play left, and gave it a 1/2 a turn afterwards.
Not sure up and down is the right way, I spin the pushrod and tighten the nut until I feel the tension grab the pushrod, that's zero lash, but your prob pretty close. Then tighten 1/2 turn.
Brian
Brian
