additional parts for install of clutch?
Old Jan 28, 2003 | 04:41 PM
syacoub's Avatar
I'm ordering a spec 3 carbon clutch. What additional parts do I need? Any special throw out bearing? Does spec use their own?
I also heard of replacing pilot bearing- but putting in a brass bushing instead. And anything else? Any seals too?
Old Jan 28, 2003 | 04:56 PM
DaveW 396ci's Avatar
The clutch should include the TO bearing, PP and clutch plate. It may also include a new flywheel if you ordered one. No seals to buy unless you have a problem with your crank's rear main seal. If so then you may want to buy a replacement rear main seal and replace it while you have the clutch out.
As for the pilot bushing/bearing, that is a toss up. You can replace it pretty easily, but which to use ( the bushing vs bearing) is a toss up. I have used both many times. I don't notice a difference with either one.
DaveW
F'n1996Z28SS
Aug 23, 2023 11:19 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
siguy
Nov 27, 2014 10:07 AM
