Acceptable fuel psi bleeddown?
Old Jun 3, 2003 | 03:41 PM
JSK333's Avatar
Question Acceptable fuel psi bleeddown?
What's acceptable once you turn the car off?
When I first turn it off, it seems to drop to about 35, then slowly rise to 40 over about 15 seconds, and hold there for at least a 1/2 hour.
However, after about 1.5 hours after shutdown, it bled down to around 32 psi...
I also checked it about 12-16 hours (the next day) after shutdown, and it was at 0.
So, what is acceptable? How long should it hold pressure? And if this isn't acceptable, would it be my injectors or regulator leaking?
My fuel pressure at idle is about 36.5, and at WOT it is about 43.5, which seems to be normal. So, I'm thinking that the FP regulator is ok...
I'm trying to hunt down a low MPG I've been getting for awhile, and a bad stumble under low RPM load when started first thing in the morning (lasts about 5-10 mins).
Thanks!
Old Jun 3, 2003 | 08:42 PM
n2oCamaro's Avatar
Your fuel pressure sounds normal.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Alex Barnes
Jan 24, 2015 10:21 PM
