Accel Injectors?
Old Oct 1, 2004 | 10:49 AM
GR8WHTZ's Avatar
Accel Injectors?
Does anybody have any expiriences with the 24/lb. Accel injectors? I'm thinking of replacing mine, and want to know if they are an ok option...
Thanks,
Dave
Old Oct 1, 2004 | 12:22 PM
n2ceptor's Avatar
Re: Accel Injectors?
Yes and Yes.....
Old Oct 1, 2004 | 12:54 PM
1996LT1NY's Avatar
Another option is the SLP/LS1 25# injectors....theyre on special now for $100 per set
Old Oct 1, 2004 | 06:27 PM
96capricemgr's Avatar
Reports of long crank times seem common with these and I could not quite get the tuning down for them, I would suggest the much better known tuning setup SVOs or the LS1 injectors. With any non-stock injector a new tune is highly recommended so you might as well stet up a size so you never have to buy bigger ones down the road.
Aslo don't buy into the aftermarkets push that new injectors are a performance mod, there are two reasons to replace injectors one is they are failing and two is you are putting out more power than they can fuel(or plan to do so). The stock injectors should be good to 400hp or so. From your mods list I will say you are nowhere near taxing their fuel delivery limits so only bother spending the money if the stockers are going bad.
Old Oct 1, 2004 | 11:04 PM
12SCNDZ's Avatar
30# Accels...No tuning problems...No long start problems...No injectors problems at all. It runs 12.0 with them.
Frank
Old Oct 2, 2004 | 07:31 AM
GR8WHTZ's Avatar
Thanks guys,
I ordered the accel injectors, as mine ARE failing. (well one or two of them anyways) . This current engine will never see more than 400hp, so I should be all set with the 26#ers... I thought about the SVO's but no one could give me a ford p/n, and i'm not sure I want ford parts on my engine anyways .
Dave
Old Oct 2, 2004 | 07:43 AM
wicked_95z's Avatar
Does anyone know what pressure the Accel 30#er's are rated at?
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
autoxr166
Sep 25, 2015 04:21 PM
95blkss
Sep 22, 2015 03:18 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
