accel distributor
Old Sep 18, 2008 | 07:40 PM
z28camaro1090's Avatar
accel distributor
are the accel distributor dual vented or no? and also how hard is it to go from the regular to the dual vented
Old Sep 18, 2008 | 09:10 PM
GreasyB's Avatar
Do not get the accel distributor. I had very bad luck as well as I have heard of others having bad luck with them.
Old Sep 18, 2008 | 09:31 PM
texastransam96's Avatar
i have known a few people whote "attempted" to run this distributor, and none of them had it last for more than a month or two... it is has not proven to be a very good distributor at all...
Old Sep 19, 2008 | 01:17 PM
so do not buy the accel. i want a good one but not to expensive. and also i want dual vented
Old Sep 19, 2008 | 02:50 PM
any ideas of what i should get
Old Sep 19, 2008 | 03:34 PM
camaro1fastz28's Avatar
a stock one
Old Sep 19, 2008 | 03:44 PM
i was trying to go with something better and dual vented so i do not have to replace anytime soon plus gain alittle performance
Old Sep 19, 2008 | 05:07 PM
96' Formula WS6's Avatar
There is nothing wrong with the stock piece, youre not gonna get any more performance from a different brand. If you really want a vented one then you can get a vented unit then change it out with a later model timing cover (95-97) and chain. Not sure if the water pump is the same or not but someone else should. The upside is that oyu can run a double roller timing chain with this setup.
Old Sep 19, 2008 | 06:03 PM
rcantrellz28's Avatar
I have the Accel opti on my car now. I have had an MSD as well, the Accel has outperformed the MSD. I had the MSD on for about 1 year and when I did I had to return it ( something wrong with optical sensor), got it back and it started doing the samething within a month and by then my warranty was up and they wouldnt touch it. I got an Accel opti brand new for $199 and definetly had second thoughts about it, but did it anyway. I have now had it on for a little more than a year and a half and put 15-16,000 miles and havent regreted it.........yet. but when it goes, I will go back with a GM unit. So honestly , I would recommend a GM opti.
Old Sep 19, 2008 | 06:50 PM
I don't know what you mean by "dual vented", but for your 1993 the only vented opti you can buy to just bolt on would be the MSD one. They added vents to their pre-95 optis.
To convert to a regular vented opti, you would have to spend quite a bit more money and work to get there.
Old Sep 20, 2008 | 08:01 AM
2000GTP's Avatar
You won't see any gains with the aftermarket opti. I would just go with a factory replacement.
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
autoxr166
Sep 25, 2015 04:21 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
