AC line to back of compressor?
Old Aug 23, 2003 | 10:40 PM
Mr.Whitey's Avatar
I just put a new line on the back of the compressor since I trashed the fitting going to the condenser. The compressor was out of the car. I put the compressor back in and tried to install the line. It's the line that actually has two connected at the back of the compressor. I tried for two nights now to get the mounting surface totally flush. The lines are in and all seems good but when you look at it the head of the bolt is visible but so is a tiny part of the threads between the mounting bracket and the condenser itself. Does anyone either have one out of the car or possibly take a look at it installed and see what it looks like please?
TIA
Old Aug 23, 2003 | 11:06 PM
HardcoreRM125's Avatar
All that stuff was off my car when i got it, since it was totalled, and when i put the new condensor and lines on the back of it, it left a little ( less then a 1/16" ) gap, and i was tightening that thing as hard as i could... Dont want to strip it out ... And no matter how many times i tried it jsut wont tighten up, i think if the seals are in it rite though , it shouldnt leak, only way to know is to hook up a charging bottle and see .
Old Aug 25, 2003 | 07:01 PM
Mr.Whitey's Avatar
I'm looking at about a 1/16" gap too. I also figured, as you stated, that I would wait to see if it leaks. I've had enough of that fitting for a few weeks anyway. I thought that I was going to get my arm stuck in there several times.
Old Aug 25, 2003 | 08:43 PM
Haha yea, that has to of been one of the most frustrating things in putting this thing together. I cant even remember how many tools got thrown across the yard and multiple cursing sessions over that gap ... I wish someone who has a working AC could show us a Pic and let us no lol
Old Aug 26, 2003 | 05:40 AM
predator's Avatar
that is normal gap there that is the way it was made
Old Aug 26, 2003 | 12:59 PM
TheHeadFL's Avatar
There should be no gap!!
If you've removed the compressor, you have TWO bolts that will fit that hole, of DIFFERENT LENGTHS! I made the mistake of using the longer bolt on the compressor lines and had this same problem you are having. Use the shorter bolt... just have to figure out where you had put it
Old Aug 26, 2003 | 04:09 PM
Mr.Whitey's Avatar
I don't follow what you're saying. There is only one bolt holding the fitting onto the back of the unit. It's the same bolt that was on there before. I messed up the fitting that goes to the condenser so I had to replace the whole line. I took the bolt off and put it right back on.
Old Aug 26, 2003 | 04:25 PM
lol kinda hard for me too find the exact bolt, i was given a plastic cooler, FILLED with nuts and bollts for the car, as well as a truck load of parts and was told "Put it together"...
At any rate, i found a bolt that seems to be the right length, bolted it down and tehre is a gap, and when i bolted it into the compressor while the lines were off it threaded almost all the way in ( Like a gap left of a litle less then that of the line retainer ) So i think its the right length, only problem is the bushing seal thingys hold it out ...
Old Aug 27, 2003 | 04:10 AM
TheHeadFL's Avatar
You said the compressor was out of the car and you reinstalled it. Make sure the bolt is absolutely correct. There are two bolts that will fit in that hole, and only one is the right one.
99TransAmWS6
Feb 12, 2015 07:23 PM
Jan 23, 2015 01:13 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Snoman73
Nov 17, 2014 07:22 PM
