AC Kills my battery
Old Aug 15, 2003 | 11:12 AM
Wildwill532's Avatar
AC Kills my battery
I never use my AC and I did the other day and it seemed alright, but then I get home and shut the car off, I go back out to start it the damn things dead, so I jump it figuring it will return to normal and I stop for gas, Its dead , I go to work and thats about 10 miles from my home, shut it off go out and its dead now the bastard doesnt charge for anything, I think it might be the alternator but im not sure what do you think could be causing this bull****!
Also the battery usualy stays at 13 or a little below, THIS NEVER HAPPEND UNTIL I RAN MY AC!
Old Aug 15, 2003 | 11:14 AM
mc63's Avatar
Time for a new battery!!!
Old Aug 15, 2003 | 11:20 AM
But the thing is I bought it Less that a year ago from walmart with the 3 year warrenty? It shouldnt be bad already could it!
Old Aug 15, 2003 | 11:38 AM
Would I need a new alternator or what someone help before I go to work please! I dont know how the battery could be bad already but is there any way to know for sure?
Old Aug 15, 2003 | 11:45 AM
EaC95Z28's Avatar
you can check it with a load tester. get one from your auto parts/hardware store and connect the cables to your battery. then put the load on the car with the car started and if it dies in 15 seconds or so then your batteries shot. also the load tester tells you if its chargine at 14.4 volts i believe. or you can take it to autozone advanced and they can test your alternator and battery inside the car!
Old Aug 15, 2003 | 11:51 AM
Thanks for your alls helps!
Formula Steve
Sep 19, 2023 08:31 AM
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
68camaroboltz
Oct 5, 2015 01:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
