abs light comes on but only sometimes
Old Sep 21, 2003 | 12:31 PM
1darkz's Avatar
anybody ever have a problem with the abs light coming on once in a while?i shut the car off and its gone
Old Sep 21, 2003 | 12:49 PM
MTL_Z28's Avatar
I have the same problem as you. Mine seems to come on after I'm done washing the car sometimes. I don't know if it's normal.
Old Sep 21, 2003 | 01:05 PM
grossesexy's Avatar
mine only seems to come on the morning after its rained really hard, so im guessing its just some flaw.
Old Sep 21, 2003 | 04:37 PM
D James's Avatar
yep mine turns on randomly, just every so often, when it does I shut the car down and restart it, to make sure it goes off, and it always does, not sure why it does it, maybe a corroded wire or something or rain as others have said
Old Sep 22, 2003 | 04:32 AM
predator's Avatar
check the 3rd brake light if the bulb is blown the abs light will come on intermittently
Old Sep 22, 2003 | 08:12 AM
BlownF1's Avatar
Check the ground post on the passenger side fender, just behind the red plastic power block. Clean the wires and the ground point on the fender and tighten it up.
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
