ABS/INOP light staying on
Old Jan 4, 2008 | 07:13 PM
DEEZ-Z28's Avatar
Here we go again. lmao I have a 95 Z28 Lt1. While driveing tonight under normal conditions my ABS/INOP light came on and stayed on. I read in the owners manual that if this happens I should shut the car off and let it reset itself, which I did. However upon restart the light still stays on. Sooooo, to check to see if the ABS system was working I took the car out on the highway and at a speed of 65 mph slammed the brakes hard. Guess what,,, no lock up. It appears that the system is still working fine. The owners manual also stated that if the ABS system was failing that the brake pedal would feel hard or stiffer than normal. Not the case. Everything seems to be operating as usual. Any input as to what could be causeing this light to stay on would be appriciated. I know there is a ABS relay in the fuse block, but if this were bad wouldnt the system fail? ... Thanks
Old Jan 4, 2008 | 07:15 PM
dangalla's Avatar
any codes?
and this really belongs in the general section not lt1 tech
Old Jan 4, 2008 | 09:49 PM
bombebomb's Avatar
If you do a search im sure you will turn up some things, I know iv read about it a few times before, but that was atleast a year ago and iv forgot all about it.
Old Jan 4, 2008 | 10:11 PM
feenix88's Avatar
Have someone check all of your brake lights. Then check the third brake light switch which is right behind the brake pedal. Sometimes they go bad. Pull it out and figure out how it works (its simple electrical contact) and you can usually put it back together and fix it. I had it happen 3 times now.
Old Jan 5, 2008 | 08:47 AM
wht-z's Avatar
like feenix said check your 3rd brake light it is wired in to activate the abs/inop light when one of the bulbs is out
Magenta_Hearts
Mar 29, 2017 08:54 PM
mattstrike
Mar 11, 2015 07:33 PM
eazyZ
Mar 1, 2015 07:12 AM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
squarehead
Jan 15, 2015 07:02 PM
