ABS INOP light came on. Why?
Old Aug 9, 2003 | 03:36 PM
Smokn '94 Z's Avatar
Question ABS INOP light came on. Why?
Any ideas on why this happend. I shut the car off & then started it & it stayed off. This is the second time it did this since my Head install.
Old Aug 9, 2003 | 06:38 PM
Z28max's Avatar
I've had mine come on and stay on a couple of times. Both times one of the upper brake lights in my spoiler were burned out. As soon as I replaced them it went out. I would check that first if you haven't already.
Old Aug 9, 2003 | 06:49 PM
moparman's Avatar
If you have a plug wire to close to the brake line, that will set it off as well.
Old Aug 9, 2003 | 11:47 PM
Lightbulb
Well my brake lights all work. I am curious as to why the plug wires will set it off. It may just be coincidence but I am running my wires along side the valve covers which some are close to some brake lines....
Old Aug 10, 2003 | 08:37 AM
Plug wires close to ABS sensor wires, not brake lines can cause an ABS light.
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
rwferguson43026
Feb 6, 2015 10:06 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
