ABS INOP light came on. Why?
Any ideas on why this happend. I shut the car off & then started it & it stayed off. This is the second time it did this since my Head install.
I've had mine come on and stay on a couple of times. Both times one of the upper brake lights in my spoiler were burned out. As soon as I replaced them it went out. I would check that first if you haven't already.
Originally posted by moparman
If you have a plug wire to close to the brake line, that will set it off as well.
It may just be coincidence but I am running my wires along side the valve covers which some are close to some brake lines....
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
