ABS inop light and brake light stays on!
Old Mar 3, 2004 | 08:21 AM
Skiwee10's Avatar
Hello everyone. My ABS inop and brake light come on and stay on every time I start the car. It has been doing this for several months. I was told by the dealership it needs a new EBTCM(electronic brake control module) and they wanted $1,000 to do it. I don't have that kind of money. I have found several places that sell the part for less than $100. Anyone know where this part is located, and if so, how to change it? Any help would be appreciated. Please email me at chrisrsnyder@gmsnyder.com if you can help. My Camaro is a 1995 LT 1 with the 5.7 liter, V8.
Old Mar 3, 2004 | 08:43 AM
Riddlerlt1's Avatar
I had the same prob about a year ago. Some ppl have been having the same prob on this board recently. I just said screw it and let it stay on. It eventually stopped coming on and now my ABS works just fine. It hasnt came on in quite a long time. DO a search on this board...lot of info.I wouldnt waste the money if i were you.Its probably just a ground.
Old Mar 3, 2004 | 08:46 AM
Skiwee10's Avatar
ABS light
How long did it take for yours to shut off? Mine has been on for about 3 months now?
Old Mar 3, 2004 | 08:56 AM
Riddlerlt1's Avatar
ill find you a link to the story
Old Mar 3, 2004 | 09:01 AM
Skiwee10's Avatar
Thanks!
O.k. that would be great!
Old Mar 3, 2004 | 09:02 AM
Riddlerlt1's Avatar
http://web.camaross.com/forums/showthread.php?s=&threadid=229751
http://web.camaross.com/forums/showthread.php?s=&threadid=187689
these are some links to some threads about the same thing
Old Mar 3, 2004 | 09:32 AM
19formula94's Avatar
mines been on for over a year....just put some electrical tape over the light
Old Mar 3, 2004 | 09:46 AM
Skiwee10's Avatar
I sent you an email to dberry08@yahoo.com with a couple questions. Any help would be appreciated!
Old Mar 3, 2004 | 10:27 AM
orrink's Avatar
Mine did the same thing and it turned out to be a light in the spoiler burnt out. Have that checked first.
Old Mar 3, 2004 | 10:31 AM
americanmusscle's Avatar
Have you checked your ABS sensors? As for the brake light I had mine stay on after I changed out my battery. Disconnect your negative from the battery and leave it off for like 2 min. and see if the light went away. I solved my ABS light problem by just replacing the messed up sensors that were on there. As for 1000 bucks to do the job, man that sound like alot. If I were you I look around or ask to see if anyone would do it for less. Good luck.
Old Mar 3, 2004 | 10:40 AM
ChuckZ28's Avatar
I had exactly the same problem with both ABS INOP and BRAKE lights on last month. I had to bleed the brakes using the old pedal method. There is a shuttle valve inside the ABS unit that got stuck and bleeding the brakes using the pedal (not a speed bleeder) was able to dislodge the valve and everything worked normal agian.
Hope this helps
Old Mar 3, 2004 | 11:16 AM
95 Silver TA's Avatar
I just had this problem last friday....But My ABS Light was ON and my Brake and Low Trac Light were BLINKING
Here is the last post on how I fixed it.
http://web.camaross.com/forums/showt...hreadid=187689
Now I have 250 Miles on the car and the problem has not returned.
Hope that helps,
Claude
Old Mar 3, 2004 | 11:41 AM
Black_Z28's Avatar
Why would replacing the plugs wire addect the ABS system? I understand why cleaning the ground posts off, but I don't understand why plugs wires would affect this problem. Any know why?
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
