ABS INOP Light on
Old Mar 25, 2004 | 08:25 PM
Ricardo's Avatar
ABS INOP Light on
The ABS INOP light came on today for a second time in a two month interval. After shutting the car down and starting again the light will go off and everything seems normal. Any clues as to what might be causing this? I remember having read once that metal shavings adhered to the sensor in the differential could cause this. Any suggestions as to what to look for appreciated.
Old Mar 25, 2004 | 08:55 PM
fuzzyz28's Avatar
Mine did the same years ago; ended up being both the ABS control module AND brake motor. Dealer fixed it; have part #s if you end up needing them.
However, those parts new are $$$$$$$$
Hopefully it's not that.
Old Mar 25, 2004 | 09:12 PM
Clean and tighten the ground that is on the RH shock tower (near the red plastic + junction block).
grabbem88
20
Dec 27, 2015 07:42 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
