ABS INOP light on??
Old Dec 9, 2003 | 06:03 PM
Zerosheaven's Avatar
ABS INOP light on??
Just changed my plugs and wires to msds and ngks, took of the alternator to do it. put everything back together but now when i drive for about 2 minuts or so, the ABS INOP light goes on. any ideas??? did i put the accessory belt on wrong or something? thanks.
Old Dec 9, 2003 | 06:13 PM
slopokrodrigez's Avatar
A member named SJS posted that he had a plug wire too close to something and it caused the problem you're talking about. If you don't see something obvious the plug wires are close too, then PM him and ask.
I think he was talking about the ABS motor assy near the master cylinder.
Old Dec 9, 2003 | 07:55 PM
k thanks for the info, in the meantime, anyone else have any ideas?
Old Dec 9, 2003 | 08:15 PM
S.J.S.'s Avatar
I Pm'd ya. I'm 100% sure its that, if thats what your telling me. If it was working fine before the install than thats it. Just make sure your plug wires aren't touching any harnesses against the engine bay walls. Keep them closer to the motor and it'll go off. No need to reset the comp or anything.
Old Dec 9, 2003 | 10:57 PM
Fuels94TA's Avatar
This may sound crazy but on TAs' the third brake light is out it will trigger the ABS inop light on the dash. Check to see if the light is blown. This has happen to me.
Vinny
Old Dec 9, 2003 | 11:06 PM
Vader's Avatar
If the light is on, then a code has been stored, and therefore you can scan it to find the problem. Guessing isn't going to help - the code will.
Old Dec 10, 2003 | 08:25 AM
IslandZ's Avatar
Also check the fuse in the driver dash panel. I used to get an ABS INOP light and it turned out the fuse was blown.
Old Dec 10, 2003 | 08:29 AM
onefastz28's Avatar
my abs inop and my BRAKE light are both on, and i never touched anything under the hood. maybe i'll check that fuse too.
Old Dec 10, 2003 | 08:44 AM
1FASASZ's Avatar
can you tell me what you think it is to. ive had the same problem since i installed my headers
Old Dec 10, 2003 | 05:58 PM
IT WORKED!!!
what you have to do if something like this happens it take any spark plug wire that is near or touching the abs wires and move them away. they are blue. thanks S.J.S.
Old Dec 10, 2003 | 11:07 PM
S.J.S.'s Avatar
Your welcome dude. Glad to help.
Old Dec 11, 2003 | 06:16 PM
whitedakota's Avatar
Talking spark plug wire/ LF wheel sensor
S.J.S.
it fixed my abs inop problem too!!! thanks dude...i was fixing to take the dash apart and snip the wire to it.lol..
steve-o
grabbem88
20
Dec 27, 2015 07:42 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
