Abs Inop
Old Jan 30, 2004 | 07:01 PM
sean1997ws6's Avatar
Abs Inop
The ABS INOP light is comming on in my car and the brakes are trembling bad. I was wondering if the comp. will tell you exactly what is the problem when i scan it. The pads are fine and the rotors are good. Just wanted to know if it will tell me what is the problem before i spend the 25 bucks to get it scanned.
Old Jan 30, 2004 | 07:35 PM
mr_camaro96z28's Avatar
It won't necessarily tell you the exact problem it might say bad sensor on right rear and something else might be causing the faultor or something similar to. It might give you something like speed sensor inop, but it will get you in the ball park and help out.
Old Jan 30, 2004 | 10:47 PM
lt1hatesme's Avatar
having your third brake light out, will set off the INOP light. also, roughting plug wires too close to the ABS unit will set it off also.
Old Jan 30, 2004 | 10:52 PM
Ill check that, but could that explain the trembling in the brakes?
Old Jan 30, 2004 | 11:08 PM
lt1hatesme's Avatar
Question
i dont know, sorry
Old Jan 30, 2004 | 11:21 PM
Seal's Avatar
never heard of that
Old Jan 30, 2004 | 11:33 PM
S.J.S.'s Avatar
Yep its true. My friend car had his third light out and he had the ABS INOP light also. As for me, when I redid my motor I zip tied my wires to the Abs line to clear the headers and ended up throwing the light.
Old Jan 30, 2004 | 11:56 PM
Seal's Avatar
that is the weirdest thing i've heard
i recently changed mine, and i never had the light... my roommate told me they were both out (2 bulbs in the 3rd stoplight)
Old Jan 31, 2004 | 01:47 AM
whitedakota's Avatar
my abs inop light came on just after i changed plugs and plug wires...turned out to be a plug wire too close to the front wheel sensor cord that deals with the abs.
re routed the wire away from that and no more abs inop light!
check your plug wires!
jmo,
steve
Old Feb 1, 2004 | 10:36 PM
Fatdog's Avatar
Cool
The third brake light is wired to the abs(indirectly).The shuttering is ,I believe,from warped rotors.Have you been stopping really hard lately?Overheating.Anybody else?
Old Feb 2, 2004 | 12:00 AM
carlos64030's Avatar
As for the vibration, sounds like a warped rotor or bad wheel bearings.
IndyZman
Oct 22, 2015 02:17 PM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
realistyc
Jul 28, 2015 07:32 PM
