? about timing chain install w/ electric water pump
Old Apr 16, 2005 | 06:35 PM
Beyonce Knowles's Avatar
I'm converting to an electric water pump with my new timing set, and I was wondering if I just unbolt the old driveshaft and its gear to make way for the new timing chain or if there is more to it. I'm talking about the small gear on top. Looks like if I remove it, it will just leave a hole into the lifter valley.
Did a search, wasn't really sure what to search for, proved unfruitful.
Old Apr 16, 2005 | 06:42 PM
93black-ta's Avatar
Re: ? about timing chain install w/ electric water pump
you can leave the hole if you want. it really doesnt matter. my machine shop plugged mine- so i left it but most people leave the hole
Old Apr 16, 2005 | 06:55 PM
Now how do I get the sucker out of there? I removed the two torx bolts in front, and I figured it would just pull out. No luck. What else do I need to do to get it off?
Old Apr 16, 2005 | 07:10 PM
93black-ta's Avatar
hmm, mine came right out. id say try tapping it out from the back with a hammer and punch.
Old Apr 16, 2005 | 09:31 PM
69vette's Avatar
you have to pry it out. its pressed in
Old Apr 17, 2005 | 10:04 AM
speedmiser's Avatar
Yep, pry it out - I used a big screwdriver.
Old Mar 15, 2006 | 06:08 PM
rob2299usa's Avatar
When I pulled my waterpump driveshaft out the bearing stayed in the block. Does anyone know how to get it out or if it's ok to just leave the bearing in the block?? I was planning on putting a freeze plug in there but if it's too much effort I'll just leave the bearing there. O and I don't really wanna take the intake off to pound it out the back. Thanks for your help in advance!
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
