About to start my 383
Old Nov 27, 2005 | 09:10 PM
silverz28's Avatar
I'm finally almost done with my rebuild. It is a 383 with forged Eagle crank, SRP pistons and forged eagle H rods. I only have to hook up my off road pipe, put in my new computer from PCM for less, and fill it with fluids. My quesions is: should I just start it right up or prime it somehow? I did prime it a while back before I dropped it in the car but that was so long ago. About 3 months ago. Should I pull the coil wire or pull the fuse for the fuel pump or what?
Old Nov 27, 2005 | 10:04 PM
93black-ta's Avatar
Re: About to start my 383
if youve primed it and saw oil pressure on a gauge then your good to go. if you didnt use a pressure gauge then i would turn it over till you see pressure on a gauge. id say pull the coil wire and pull the fuel pump fuse.
cheapchevy
Apr 8, 2015 08:48 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
