? about roller rockers
I was looking to maybe buy some rockers. I have a basicly stock car besides the cai and cat-back exhaust. I want to buy some rockers but dont know much about them. can someone point me in the right direction? Im not into heavily modifying my car because i dont have the technical knowledge to do so. I just want to install them easily without having to modify valve covers. Im not ever going to put new heads on or do a camshaft swap or anything like that. Ive heard about 1.6 magnums or crane 1.6 sa. I really need help in chosing.
In your position the cranes will fit you better. Your going to need to know how to adjust valve lash upon installation. (good to have somebody that has done that before nearby)
Roller rockers reduce friction compared to the stamped stock ones, along with change the ratio depending on the number 1.5, 1.6, 1.7 etc.
They make your valves open a little more, from what I understand. It is close to making your cam ever so slightly bigger but from the opposite end of the pushrod.
To my knowledge you shouldn't have to modify your valve covers with the cranes being they are narrow profile.
You want to get Self aligning (SA) unless you get hardened pushrods and guide plates.
I would go with headers before I went to rockers for bang for buck buddy. You will smile after putting set on.
Would these be the one's you mentioned http://store.summitracing.com/partde...6&autoview=sku. Would i need anything else to go with them,like new springs?
I know you say you dont want to do anything else after these basic mods, but you never know how deep you can get into modding down the road. So thats why I would recommend keeping your options open via spring choice.
If it were me I would go with a hotcam kit after your headers. It is a mild cam that would work with everything you are putting on your car. I believe it includes the crane rockers and springs and cam.http://store.summitracing.com/partde...2&autoview=sku
Your definitely making the right move about going with headers first. It will let the motor breath much better.
You could always go with a set of LT4 springs as well, granted they will be more then enough to handle the 1.6 rockers, but won't be adequate for both rockers and a cam. Still, for the 35 bucks that a set costs, it isn't a big loss either.
Roller Rockers
Makes you a better mechanic. I have done things I never thought I would do with my car. Header install is not easy, but it is only once and some re tightening bolts. However adjusting valve lash is not a newbie game either.
headers, UD pulley and 1.6 crane SAs on stock tune and springs got me 305RWHP. Also, before a comment on the springs - I road raced it for 3 years and no broken springs - 6K RPM all day long. I'd do springs if I went to a bigger cam. $.02
