About This Lunati TIMING SET Summit Is Carying Now?
ok i just got off the phone with summit and they said that this PN#LUN-93094 for the timing set come with LINKBELT and CHAIN? what the hell does that mean? is the translated into CHAIN, CRANK and CAM SPROCKET? someone take a look at
THIS its lunati's timing set just scroll down to part number #93094 it says Chevrolet LT-1 Single Keyway Linkbelt Chain
so is this gonna be comparable to the EXTREME DUTY TIMING SET???
Originally posted by InjectedSS
really? eh i guess ill go with the extreme duty then
$300 or around there (retail) is simply too much for a timing set.Hint: replace the WP driveshaft assemby (as a unit that includes the gear) and don't just try to replace the WP gear (on the shaft). It is press fit on that shaft and no fun for the backyard mechanic to have to mess with. WP Shaft assembly GM#10219554 $37.31 / 2 "O" rings GM#12553792 @ $1
Originally posted by Don 97 SS
I just installed an ED timing set when I put a new cam and lifters in. It is much stouter looking than the whimpy oem chain. I was pleased with it and the results so far. I defintely recommend it as the replacement option over what most have on there now. The down side it the price!
