? about LE2 H/C
Old Oct 17, 2012 | 01:21 PM
D-HUEz28's Avatar
? about LE2 H/C
I've decided that I want to upgrade the top end.I've done a tad bit of research and I looking at going with the LE2 H/C. Now my question is with that setup, the normal bolt ons, a 3000 stall and a stock rearend, am I going to have to worry about grenading the rearend as soon as I get a solid launch? All help/ advice is appreciated.
Old Oct 17, 2012 | 01:23 PM
D-HUEz28's Avatar
Re: ? about LE2 H/C
For got to mention that my z28 is A4 and I've got 3.73s.
Old Oct 17, 2012 | 01:44 PM
RamAir95TA's Avatar
Re: ? about LE2 H/C
Automatics are far more gentler than M6s so you're at an advantage there. But if you put drag radials or slicks on you have a much greater chance of breaking the rear. Remember it isn't so much horsepower that breaks the ring and pinion as it is shock loading.
Old Oct 17, 2012 | 04:23 PM
bowtiedad_z28's Avatar
Re: ? about LE2 H/C
You could break the rearend with a stock motor. It has been done. Its the weak link in these cars.
Old Oct 17, 2012 | 05:56 PM
D-HUEz28's Avatar
Re: ? about LE2 H/C
So basically the stock rearend is a ticking time bomb?
Old Oct 17, 2012 | 07:27 PM
Bersaglieri's Avatar
Re: ? about LE2 H/C
The rear end is a risk, as with anything performance, but I wouldn't call it a ticking time bomb. I've seen lots of guns running low 11's with stock rears without issue. I'm talking every weekend at the strip. Then again I've seen guys break them on the street.
I'm not sure what camshaft/setup you plan on running but 3000rpm stall is good for a stock motor. A LE2 sized cam is probably going to want something in the 3400-3600 range.
I run a Moser 9" in my A4 383 car, a stock rear in my M6 heads and cam 350. I'm not worried about the stock rear at all unless I start to beat it up at the track on slicks.
-Dustin-
Old Oct 18, 2012 | 08:19 AM
D-HUEz28's Avatar
Re: ? about LE2 H/C
-Dustin-
I planned on getting the LE cam something like .230/.236-.232/.240 so Ill look into getting a higher rated stall. Thanks for the advice guys. I think Ill take a trip to my salvage yard and try and find a replacment 10 bolt and start putting cash in to the "blown rearend" rainy day fund...just in case.
9t4lt4z28
Oct 2, 2015 10:28 AM
Schul365
Aug 25, 2015 05:47 PM
tnorm077
May 23, 2015 09:10 PM
Nutty's96
Parts Wanted
May 12, 2015 09:37 PM
Bignasty85
Mar 3, 2015 04:05 PM
