? about cam swap
Old Dec 19, 2008 | 12:23 PM
red1984's Avatar
? about cam swap
I want to install a CC503 this spring. Can I get away with just changing the valve spring? Or would I have to change the pushrods, locks, retainers, etc? I am on a very small budget. Thanks!
Old Dec 19, 2008 | 01:34 PM
dubbsix's Avatar
Im doing a swap to a 503 and i am also on a tight budget. If you do the cam, you should upgrade the valve springs. If you are planning on going with high ratio NSA rockers you will probably need hardened push rods.
Old Dec 19, 2008 | 01:51 PM
red1984's Avatar
Later on this year, probably next fall/winter, I will buy 1.6 pro mag, 7/16 rocker studs, guide plates, and a 58mm TB. I would like to know if I can get away with not having to replace the rockers at this time. I also would like to start saving up for a different rearend.
Old Dec 19, 2008 | 03:23 PM
dubbsix's Avatar
Upgrade the valvesprings and you should be OK. Obviously getting a spring that comp says will work with the cam...
Old Dec 19, 2008 | 04:43 PM
87bandit's Avatar
here's what I did for my total budget setup cc503, so you can know how much you have to spend. and yes it works
10308-1 Crane Dual Coil Kit (Includes shims, locks, retainers) $166.95
http://store.summitracing.com/partde...rt=CRN-10308-1
63-1418-16 Comp Magnum Rockers 1.6 SA $189.99
http://www.thunderracing.com/catalog...vid=4&pcid=108
63-7808-16 Comp Hardened Pushrods 7.200" $38.99 (OPTIONAL)
http://www.thunderracing.com/catalog...vid=4&pcid=106
Old Dec 20, 2008 | 08:57 PM
red1984's Avatar
CC503 with 1.6 RR VS. Hotcam kit - How much of a difference would there be in track times (with the mods in sig)? The Hotcam kit would fit my budget a little better. I know that the CC503 would have a little more horsepower but I am more interested in track times, not HP numbers.
Old Dec 21, 2008 | 06:05 PM
87bandit's Avatar
from what I've seen there's about a 2-3mph trap difference
plus the hot cam kit leaves little room for growth and if you decide to change your cam later down the road pretty much zero parts in the kit are reusable for bigger cams. the springs are rated for what the cam lifts, the rockers are SA.
if you feel you'll be satisfied with the hotcam's gains or don't mind redoing things later if you decide to upgrade then by all means go for it
Klypto
Mar 23, 2016 09:05 AM
jj_burchiel
Mar 5, 2015 07:05 AM
chuyz28
Feb 19, 2015 12:50 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
