? About 7/16 1.6 NSA Promags
Old Dec 22, 2005 | 12:41 PM
Huntr1117's Avatar
Question ? About 7/16 1.6 NSA Promags
How often do I need to adjust my Promags, or should I even need to? I've had them in for about 4 months, now I'm hearing alot of valve train noise comming from my driverside. I thought that the Polylocks would keep this from happening. How hard is it to adjust them? What do I need to do? Also when I had them installed I had them put in LT4 springs, but I kept the stock locks and retainers. Would this matter, or do I need to get the LT4 locks and retainers?
Old Dec 22, 2005 | 01:02 PM
sssalah's Avatar
Re: ? About 7/16 1.6 NSA Promags
They don't need to be adjusted once they're set properly. It does't hurt to try setting them again and if the sound does't stop it most probably a bad lifter. Also, the LT4 springs are 1.33" which is a little wider than the stock 1.25", so yes the LT4 retainers are required, locks wouldn't matter.
Old Dec 22, 2005 | 01:20 PM
Huntr1117's Avatar
I just replaced the lifters, they better not be bad. So if I do adjust the rockers again I should install the LT4 retainers?
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
