A4ers, Something I've Noticed
Old Jul 7, 2003 | 01:42 AM
Izod's Avatar
I've been wondering. I've been reading thru random sigs and such and from what I've seen, it seems that 2.73ers put down less on dynos (NOT saying their numbers are actually less!!!). Is there a possibility that because of the ratio there is something inaccurate with dyno results? Thinking about it none of it makes sense to me, but it was just something I noticed.
Old Jul 7, 2003 | 02:01 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
i've always wondered that myself... since lower gears spin up quicker... wouldn't that throw off the dyno to make it seem like you got an A$$LOAD more hp?
but, i ASSUME they put your gear ratio into the computer before hand, for it to calculate all that....
i've never dynoed... so i couldn't tell ya with enough confidence to put my car payment down....
Old Jul 7, 2003 | 02:30 AM
TheHeadFL's Avatar
Scientifically speaking, if anything, higher gear ratio cars should experience more loss at the wheels than lower. Mechanical advantage (higher ratio) increases wheel torque, but not with 100% efficiency. Higher advantage has lesser efficiency.
By the way, no gear ratio will ever affect your dyno readouts, since they can only change torque (instantaneous force) and will never affect horsepower (force over time) which is work. Dynos account for the torque multiplication anyway.
Old Jul 7, 2003 | 02:43 AM
Antz97ZNJ's Avatar
hes right, the 273's would trap higher then the 323's...so on the dyno i would imagine it would be the same
Old Jul 7, 2003 | 05:55 AM
Haskin Z28's Avatar
i trapped much higher with 3:73s then i did wityh 2:73s
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
mmf_1013
Sep 12, 2015 08:56 PM
