A4 shifting into 1st at a 30 roll
Old Feb 8, 2004 | 08:08 PM
ddlouhy127's Avatar
how can i make my trans shift into 1st at a 30 roll when i floor it?, i have a shift kit and 2500 stall. do i need to program the computer ? thanks
Old Feb 8, 2004 | 08:11 PM
MaddHatter's Avatar
If you can't do it manually (some only go down to 2, some go down to 1 on the shifter) then you'll have to have it programmed probably... Mine does it automatically with the perf trans button turned on or i can do it manually... either way it gets up and goes
Old Feb 9, 2004 | 07:51 PM
ddlouhy127's Avatar
ttt, will a hypertech work to program the trans? thanks
Old Feb 9, 2004 | 08:52 PM
Not for that.
Old Feb 9, 2004 | 09:06 PM
NewbieWar's Avatar
Well you would have to reprogram it, i forget where i saw it... but like its programmed to shift into 1rst (with 2.73) at any WOT below 31mph i believe, and its different w/ the perform option... i forget tho... your not gonna gain much power in that area anyway
Rittmeister
Aug 7, 2015 01:13 AM
Aug 5, 2015 08:35 AM
wesley81
Jul 27, 2015 11:31 AM
Boss002
Jul 9, 2015 03:33 PM
