A4 guys, how much MPH did you gain from your cam install..
Just curious as to the gain from your cam installs..
I'm curious mostly from the 224/230 XE guys, but the hotcam and other cams in a similar field would be appreciated. I maxxed out at 104 MPH w/ my headers & converter in about 78-80* weather.
Going to be heading to the track for the first time since I installed the cam in about 5* hotter weather. will probably be like 80* or so, but I'm curious as to what I should look to as far as gains go.
It's tuned pretty decently from what I can tell with PCMforless.
Thanks!
Thanks!
Re: A4 guys, how much MPH did you gain from your cam install..
Thanks!
Thanks!
Good Luck & I will be watching for your record run post!!
I've got an XE 224/230 in my car. Pulls like crazy on the street but at the track I had a ton of traction problems (suspension and tires/wheels are still stock, no tuning yet either).
I ran a 13.7 @ 102 with a 2.39 60' on street tires. On top of that, The tranny refused to shift into 3rd gear... it would just hit the stock fuel cutoff at the top of 2nd and bounce off the rev limiter for at least 2 solid seconds... that's time that the car could've been accelerating... and believe me, even with bad traction this cam pulls like crazy
I'll let ya know how how things go once I get some traction... and a tune.
Originally posted by EvlViln
Cam alone isnt it. There is traction, track conditions and driver to take into consideration.
It's all about the 60 foot.
Eddie -> I'm doin' good now with the new job
... curious, how did you run before the cam? Wondering what your MPH was.. did u have the converter in b4 the cam? (basically my old high 12 second setup)
Thanks, yeah I'm quite aware of that I'm at the track quite often
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
