987 springs good for this cam?
Old Apr 27, 2005 | 12:00 PM
speedcrazy's Avatar
i already have 987 springs installed on my heads. are these good for a 224/230 cam?
Old Apr 27, 2005 | 12:03 PM
Z95m6's Avatar
Re: 987 springs good for this cam?
They will work fine and won't require machining your heads as everyone is gonna come in and tell you that. My buddy is running them on his 224/230. I've heard that the 918's bee hives are suppose to be a lot better though. I haven't looked into them much because i already have my cam.
Old Apr 27, 2005 | 12:31 PM
raroz28's Avatar
If that's the combination cam, you might want to call them. I had the 987 spring, and they talked me out of it. I returned them for 978's. It wasn't for that exact cam, but the numbers are close.
Hate to hijack, but to 978's require machining? I thought the 987's did. I think a member here has a horror story. He didn't machine his heads like he was told he didn't need to, and the outcome wasn't so good. Might want to dig into that more.
Old Apr 27, 2005 | 03:21 PM
Z95m6's Avatar
Do a search, me and my friend Turbo_z have posted on the 987's on stock heads several times. They do work. Turbo_z had them on his stock heads and now has them on his unmachined LE1 heads. Combo will probably try to sell him their 612's which are a single spring. I would much rather have the dual 987's if i'm choosing between the two.
Old Apr 27, 2005 | 06:09 PM
94zgreenmachine's Avatar
When I purchased my cam from CM during the group purchase last year, they gave me the 612's and I was going to use the 233/239 with 1.6 pro mags. The lift cam to .569 int/ .577 exh. That would have been about max for the 612's. When lloyd set up my heads after porting, we went with 987's w/ titanium retainers. Then I talked to Lloyd a bit more and now we are doing a custom grind using 918 beehive springs. I was going to give up to much with 233/239 in my 383. Now it will be like the GM847..... with a lil' more lift
oldschool
Feb 9, 2016 09:21 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
