98 LS1 radiator...
Old Dec 6, 2007 | 03:04 PM
raroz28's Avatar
98 LS1 radiator...
Will it fit a 97 LT1?
Old Dec 7, 2007 | 12:17 PM
96m6lt1's Avatar
yes it will fit but it will be a downgrade for the Lt1 radiator.remember the Ls1 is all aluminum
and dissipates heat better than the Lt1 so in other words the Lt1 radiator will way better than the Ls1.......
Old Dec 7, 2007 | 12:25 PM
Tokuzumi's Avatar
Pardon my ignorance, but would the radiators even work, as the LT1 uses reverse cooling?
Old Dec 7, 2007 | 12:39 PM
n2ceptor's Avatar
According to my catalog, its the same until 2000......
Old Dec 7, 2007 | 01:01 PM
96m6lt1's Avatar
the reverse cooling is only due to the fact that the Lt1 cools the heads first then the block.
Old Dec 7, 2007 | 01:03 PM
96m6lt1's Avatar
the Lt1 radiator is an upgrade to the Ls1.
Old Dec 7, 2007 | 03:09 PM
raroz28's Avatar
96m6lt1 hit it on the head. reverse cooling doesn't make a difference. The radiator will work, but it's a downgrade. I was going to use it, but a guy nearby was selling a 95 radiator so I snagged that up.
The only real difference is the thickness of the core. The LS1 is 15/16" and the LT1 is 1 3/8". Much bigger.
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
