97 z28 long tube headers vs. brake/fuel lines
Old Jun 6, 2021 | 03:09 PM
cybern8's Avatar
i'm wondering if anyone else has had problems with the brake/fuel lines that run along the driver's side of the car touching the header y-pipe and having to re-route them. i can't imagine this is a good thing if not outright dangerous. the brake lines i've been able to bend enough to route them away so i think they'll be ok, but the fuel lines are still right there and i'm worried about it. i've insulated them, but the insulation is still in contact with the pipe. attached pics to hopefully better explain the situation...
fuel lines sleeved/insulated still but on the y-pipe
brake lines re-routed...
factory bracket doesn't seem to help much
Old Jun 15, 2021 | 02:04 PM
DrewHMS97SS's Avatar
Re: 97 z28 long tube headers vs. brake/fuel lines
My exhaust is a bit further away from the lines, I had no issue without heat protection, but I will be wrapping that section of exhaust with header wrap to help protect the lines.
Old Jun 15, 2021 | 08:16 PM
ACE1252's Avatar
'96 Z28, Kooks headers and y pipe. There is slightly less than an index finger width between the frame rail and exhaust pipe. About the same with lowest brake line. Been like this for 10 years. No trouble.
Exhaust to fuel/brake line clearance 001
Exhaust to fuel/brake line clearance 002
Exhaust to fuel/brake line clearance 003
Old Jun 16, 2021 | 12:17 AM
cybern8's Avatar
thanks, ACE1252 ... that puts my mind more at ease that i'll be ok.
Sax1031
20
Apr 12, 2010 12:43 PM
snakeatinZ
Parts Wanted
Apr 6, 2007 02:07 PM
ninety4three4
Parts Wanted
Jan 19, 2007 07:24 AM
lt1street
Dec 8, 2005 08:44 AM
rlax31
24
Oct 4, 2004 02:26 PM
