97 Trans am wont start...just chugs????
Old Mar 15, 2014 | 07:02 PM
bman101's Avatar
97 Trans am...just replaced the waterpump and front seals,and removed air pump stuff, re-assembly seemed smooth but now it turns over but chugs then dies...would the air not tuned out do thid or do i have something out of whack??? Any help would be great.
Old Mar 15, 2014 | 11:57 PM
4th Gen 4 Life's Avatar
Your waterpump is above your optispark. Make sure you didnt disturb any wires or if you dumped masive amounts of coolant onto it and it got inside it could mess with the ignition. Any codes popping up?
Wow got confused between the engines? well if you have stock lt1 then these suggestions may help.
Sent from my DROID X2 using Tapatalk 2
Old Mar 16, 2014 | 09:56 AM
Re: 97 Trans am wont start...just chugs????
Deleting the AIR system will not prevent it from starting. You did plug up the AIR connections on the manifold, correct?
In replacing the front seals, did you remove and reinstall the Otpispark distributor? If so, are you sure you indexed the Opti correctly to the cam dowel pin?
Old Mar 16, 2014 | 10:15 AM
bman101's Avatar
Yep the exhaust manifold got plugged, I thought I lined the Opti back up properly as it monted flush with the block(or timing cover).... can the Opti also be flush if the dowl was located into the other 2 holes in the back of the Opti??
Old Mar 16, 2014 | 10:18 AM
Yes, although most people only manage to do that by pulling the Opti down flush with the bolts.
Old Mar 16, 2014 | 10:27 AM
bman101's Avatar
Seems like I will be tearing this back down to do some investigating....what kills me is that I thought I did it without issues as everything fell into place just fine....maybe have something loose or mis aligned....I will let you guys know later today as I tear it back down....Thanks in advance
Old Mar 16, 2014 | 12:01 PM
Just one possibility. Are you sure all the wires to the ICM/coil are intact and in good condition? Have you scanned it for codes? Problems with the Opti (excluding indexing) and ICM will set codes during cranking, and not turn on the SES light.
Old Mar 19, 2014 | 08:27 PM
bman101's Avatar
Turns out the opti was NOT oriented right with the dowl....once that was right ...fired right up
Thanks for the help folks,,,,I am sure I will be on here again as I plan on doing multiple things to this TA
Old Mar 19, 2014 | 08:39 PM
Always glad to help out. Thanks for the feedback on how you solved the problem. Makes the thread more helpful to people who use the "search" function.
force10
Aug 10, 2015 08:30 AM
Jlo
Jul 22, 2015 05:00 PM
jackpawt883
Jul 20, 2015 06:32 PM
dolfan324
Jul 17, 2015 10:34 PM
Fastbird93
Jul 11, 2015 04:37 PM
