97 motor and pcm swap to 95 motor w/ pcm?
Old Jan 20, 2009 | 10:53 AM
diamondhill's Avatar
Question 97 motor and pcm swap to 95 motor w/ pcm?
i bought a 97 camaro with no motor trns. started to build a motor knowing it was a 95. idecided to swap out the pcms and harnesses.should the old pcm and harness be used to make this work??? give me some ideas
Old Jan 20, 2009 | 11:06 AM
95 motor, PCM/harness should work fine.
Old Jan 21, 2009 | 11:27 AM
96flame's Avatar
Use the harness for the car you have. The engine and body harnesses will plug together but the wires are not all in the same spots in the connectors. You can use either pcm with the harness just make sure you have the correct knock sensor in the block for the pcm you're using.
Old Jan 21, 2009 | 12:55 PM
You can find any differences in the charts on my Tech Page. Very little is different.
Old Jan 22, 2009 | 12:58 AM
JooneJune's Avatar
If the 97 once had a LT-1 in it, just use that wiring and PCM.
Like Rob said, 95/PCM/Engine harness should be fine. Rob differences in the Dash harness that may affect him?
LeftoverChinese
Jan 14, 2024 03:03 PM
nikolt1
Feb 27, 2015 09:10 PM
willismoons
Feb 14, 2015 08:42 PM
jayvar
Feb 2, 2015 10:00 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
