97 Lt1 Stalling After A Few Minutes
Hi All, Have Seen A Couple Of Similar Posts As This But Ill Explain My Problem Anyway.
Just Took Camaro Out Of Garage Storage Yesterday. Was Idling Fine And Drive Good For 10 Minutes. Took It Onto Highway And Was Clippin Along In 5th Gear And The Engine Just Died. Managed To Get It Started A Few Times To Get It Off Main Road Then It Just Turned Over Without Starting. Changed Fuel Filter This Morning(seemed To Be 1/2 Plugged) And Checked Fuel Pressures (were Within Spec). Took It For A Drive And 10 Mins Later It Died Again.
Thinking To Get A Scanner Tomorrow
Engine Light Was On While Trying To Start After Stall But Few Hours Later Was Able To Get Car Home And No Dummy Light.
Any Ideas. Thanx.
1997 Camaro Z28
30TH ANNIVERSARY EDITION
LT1 6 SPEED
Any Ideas. Thanx.
1997 Camaro Z28
LT1 6 SPEED
Replying To My Own Message Might Give Me A Complex But I Purchased A Innova Canobd2 Scan Tool This Morning And It Gave Me A P1371 Fault For The Distributor Ignition Low Resolution Circuit. Also Said Icm 4x Reference Too Few Pulses.
SEEMS TO BE POINTING TO DISTRIBUTOR OR MAYBE HARNESS OR POSSIBLY PCM....ANYONE ENCOUNTERED THIS ERROR CODE B4?
Jan 23, 2015 01:13 PM
I hope you get more help next time.
