97 LT1, rolling rockers?
Old Mar 20, 2005 | 11:47 PM
mystic-t/a's Avatar
Question 97 LT1, rolling rockers?
I was wondering if my car has rolling rockers. I have a 97 Trans am LT1. If not is it worth buying some? If so what kind? And what else is needed? Can I just pull the valve covers and change them out and be done? How much power would I be getting out of these?
Old Mar 21, 2005 | 12:22 AM
Bersaglieri's Avatar
Re: 97 LT1, rolling rockers?
You dont have true roller rockers, at minimum you need self aligning 1.6 rockers and LT4 springs for the added lift. Gains vary from 7rwhp to 15+rwhp.
-Dustin-
Old Mar 21, 2005 | 12:46 AM
mystic-t/a's Avatar
About how much would both be?
Old Mar 21, 2005 | 04:31 PM
LT4 springs around 40-50, Roller Rockers anywhere from $150 to $375. Popular ones are GMPP 1.6 RR's which are 3/8 stud and self aligning, you can also go with the better Comp Cam Pro Magnum self aligning or non self aligning 1.6 RR's in either 3/8 or 7/16 stud sizes. They run around $250-270 but if you get 7/16 size you need new 7/16 studs ($20-$40) since they stockers are 3/8 and if you get NSA you need to get hardened pushrods ($25) and GM guideplates ($15). NSA cost more since you need the extras but are more stable, as do 7/16 studs, but they deflect less than 3/8 studs. Hope this helps, I am in the process of doing the swap myself.
-Dustin-
Old Mar 21, 2005 | 05:16 PM
Kataklysm's Avatar
If you take the valve springs off you have to make sure the valves don't fall so becareful.
oldschool
Feb 9, 2016 09:21 PM
Noer
Feb 28, 2015 11:29 AM
Roadie
Feb 16, 2015 10:34 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
